Thread: Marlin trails car
Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
  1. #11 Re: Marlin trails car
    forum contributor
    May 2017
    9
    both van and car axles look very similar from a cursory glance. and yes both have cast iron diffs. So just Count the bolts around the diff circumference . 8 equals standard, 10 equals the Stronger Van version.
    these axles are VERY similar to MGB versions which effectively only differ in width and mounting brackets - the hubs/drums etc can be retro fitted.
    Don
  2. #12 Re: Marlin trails car
    Jul 2019
    61
    Above posts - just goes to prove you should not believe everything you are told by an 'expert' - He said 'only 10 cwt low-ratio diffs were CI '... APOLOGIES.
    So I was very lucky in ending up with a van axle ?
    On similar subject of very duff info. on internet > beware the MGB site that states >"... In practice Gold Seal engines have an 'E' or 'N' suffix letter as in 48G733E nnnnnn." - NO. Mine does not.
    Also beware the assertive statement '... all [Gold Seal] engines had the core-plug recesses bored deeper to accept the cup-type plugs instead of the flat type' - NO. Mine does not, it still has the 'flat type'.
  3. #13 Re: Marlin trails car
    3,138
    Quote Originally Posted by marlin1984 View Post
    There are lots of experts, anything that you read on the Internet should be treated as guidance, not as gospel. When it’s in print from a verifiable source, it’s more accurate than the bible!
    I try to verify everything I publish personally, but still mistakes slip through.
    Its when the experts are also salesmen, especially on eBay, that the mis-truths begin to multiply.
