Thread: speedometre 1800 marina
Results 1 to 7 of 7
  1. #1 speedometre 1800 marina
    frequent forum contributor Club Member kolmershlagjp's Avatar
    Dec 2015
    avignon {sud de la France]
    110
    bonjour
    is the connection of a speedometer of a 1300 marina compatible with a speedometer of 18000 marina
    what is the difference in pinout
  2. #2 Re: speedometre 1800 marina
    3,151
    My understanding is that the speedo cables for the standard 1.3 and 1.8 are identical.
    i mis read your post. I have no knowledge of the specific wiring, but the parts books suggest they are the same.
  3. #3 Re: speedometre 1800 marina
    Dec 2015
    110
    bonjour
    is the electrical connection identical from 1300 to 1800 ?
    I see an additional connection
    merci
  4. #4 Re: speedometre 1800 marina
    Ellesmere Port
    17
    I think that the additional connection that goes to the red wire linking to the Tachometer is a 12v feed from the ignition.
  5. #5 Re: speedometre 1800 marina
    Apr 2019
    47
    Wiring one of those up really requires the original plug, then you can refer to the colour codes in the wiring diagrams.
    Formally DonSayers on here.
  6. #6 Re: speedometre 1800 marina
    3,151
    Quote Originally Posted by kolmershlagjp View Post
    bonjour
    Looking at the track pattern of your two pictures, they are remarkably similar. I would say the pinouts are identical.
  7. #7 Re: speedometre 1800 marina
    Ellesmere Port
    17
    This thread from the fast marina magazine addresses the issue of changing a 2 dial unit for a 3 dial unit. The only differences appear to be the additional wiring for the Tachometer.
    https://www.fastmarinamagazine.com/v...ic.php?t=10457
