Thread: Rear Light Lens
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
  1. #1 Rear Light Lens
    frequent forum contributor Club Member AndrewKB's Avatar
    Cheltenham, UK
    104
    I have what I believe was a pretty typical rear light set-up for Roadsters - a combination light with a rubber mount and a 'racetrack shaped' red/yellow lens which just 'clipped' into the rubber mount. Does anyone know the make and, more particularly, where I can get a replacement lens? My local supplier has something which looks similar (but isn't identical) but I'm hoping to be able to replace the lens only, without having to replace the rear light. I don't mind buying the whole fitting if necessary, just to get the lens. All help appreciated.
  2. #2 Re: Rear Light Lens
    High Wycombe, Buckinghamshire
    1,938
    Here you go
    https://www.truck-lite.eu.com/m88
    And
    https://www.tridenttowing.co.uk/trai...rucklite-p8792
    Quote Originally Posted by AndrewKB View Post
  3. #3 Re: Rear Light Lens
    3,283
    Definitely Rubbolite!
    not many other options, but Volvo P1800 (The Saint) is the upmarket version.
  4. #4 Re: Rear Light Lens
    frequent forum contributor Club Member jon_wilkinson's Avatar
    Mar 2016
    Macclesfield, Cheshire
    377
    You failed to mention how much they cost
  5. #5 Re: Rear Light Lens
    Cheltenham, UK
    104
    Thanks guys, the existing is definitely a Rubbolite M88, but … the replacement lenses all seem to include a clear 'number plate window', whereas my existing one doesn't have this, nor do I need it. And, as Jon Wilkinson says, the cost!! I may consider replacing both sides with a Britax 9020 although that has a number plate window as well.
  6. #6 Re: Rear Light Lens
    3,283
    Quote Originally Posted by jon_wilkinson View Post
    They are upmarket, if you need to ask the cost, you cannot afford them!
    kit cars are remarkably like boats, a hole in the water in which you pour money!
  7. #7 Re: Rear Light Lens
    3,283
    Rubbolite 88/02/01 it is then.
    But you could always put black tape over the number plate window, or even paint!
  8. #8 Re: Rear Light Lens
    Cheltenham, UK
    104
    Or paint the inside of the Britax 9020.
  9. #9 Re: Rear Light Lens
    frequent forum contributor Club Member romeks44's Avatar
    Hornowek near Warsaw, Poland
    69
    Britax 9021 has no numberplate window.
    See eBay item 232666691469
    I have them on by Berlinetta and I’m happy with them.
    Especially the way of lens fitting with screws.
  10. #10 Re: Rear Light Lens
    1,938
    I have been told many times that my rear lights are not very efficient so I have swapped them for;
    https://www.carbuilder.com/uk/slimli...eflector-150mm
    £30 for the pair.
    Now really bright.
    I have now fitted the LED version of the Rubbolite side lights, people can also see me coming.
