Thread: Roadster Carpet Sets
Results 1 to 6 of 6
  1. #1 Roadster Carpet Sets
    High Wycombe, Buckinghamshire
    1,895
    https://www.carcarpets.co.uk/marlin-...-car-788-c.asp
    Has anyone used these guys, more importantly, has anyone fitted their carpet set for the Roadster?
    If so, are they any good.
  2. #2 Re: Roadster Carpet Sets
    Moderator Club Member
    Derby
    1,406
    Their site doesn't seem to specify whether fitment is for short or long wheel base versions . Didn't the shape of transmission tunnel and hence the floorpans change when YKC took over?
  3. #3 Re: Roadster Carpet Sets
    3,199
    Try asking them for dimensioned patterns.
  4. #4 Re: Roadster Carpet Sets
    SE London
    2,186
    I used them a few years back for my son's Mk1 but they supplied the length of carpet and I cut out the sections then sent
    what needed over binding back to them. I found the lady on the phone very helpful.
  5. #5 Re: Roadster Carpet Sets
    1,895
    Cheers matey I will give them a bell.
    Quote Originally Posted by b_caswell View Post
  6. #6 Re: Roadster Carpet Sets
    539
    Quote Originally Posted by listerjp2 View Post
    1) Stick enough sheets of A4 together and cut out templates that you can use to work out how much carpet and what shapes you need. Car carpet will normally have rubberised backing
    2) Number all the pieces and mark out which edges will want whipping
    3) Manipulate the flow rate of the screen washer jets so that they just clip the top of the windscreen and dump into the cockpit - you should be in your element then !!!!!
