Hi Just been checking the front brakes on my Roadster, have the disc setup has a 10 mm spacer to clear the disc etc, one of the nuts and stud has stripped the thread due to not being long enough, alloy wheels, any ideas anyone? thanks, Ray.
wheel studs
Re: wheel studs
I would be very cautious of spacers on front wheels.
The standard ones are hub centric, plain spacers won’t be as good, possibly the reason for your problem.MOC member since 05/97
Re: wheel studs
I will give Darren Groves the credit for this info not tried it myself but quite a few Triumph owners have done this upgrade.Ben Caswell probably not the last word on anything here!!
Re: wheel studs
Originally posted by yousay54 View PostThat's very helpful brilliant many thanks will have a look at that, cheers Ray.
My experience of M12 wheel studs is that their heads are not recessed to fit in the hubs.
Unless you are an engineer, it’s far better to use parts that were designed for the specific application.MOC member since 05/97
