Thread: Brake pipe flaring.
Results 1 to 10 of 13
  1. #1 Brake pipe flaring.
    Jul 2016
    St Austell, Cornwall
    608
    I am starting to replace all my brake pipes before finally fitting the body panels on my roadster.
    I bought a Sealey flaring kit from flea bay for £15 and tested it, was not impressed with the flare so found a better tool for £35 and what a difference.
    Guess which one is being sent back. Good reminder not to buy too cheap.
  2. #2 Re: Brake pipe flaring.
    High Wycombe, Buckinghamshire
    1,911
    Hiya
    Yep I ended up buying a better set.
    Good to see you are making progress.
  3. #3 Re: Brake pipe flaring.
    Jul 2016
    608
    Ha slowly getting somewhere Adrian,
    It seems every time I plan to spend time on it something else crops up.
    Saturday for instance, lovely day but I spent the day fixing a flush on the toilet :-(
    I can’t believe the difference between these flaring kits, it’s dangerous to use them and I must say the better one is far easier to use too.
    Cheers and keep safe, Martin.
  4. #4 Re: Brake pipe flaring.
    Exeter
    1,232
    I am also looking for a better brake flare tool. Where did you get your second compact one? There are several places that supply ones that look the same as yours, but I would be reassuring to get the exact one that you bought as it produced such a good result. Peter.
  5. #5 Re: Brake pipe flaring.
    Jul 2016
    608
    Hi Peter,
    I bought this one from Amazon, it is easy to use and does a good job. I am making slow progress as I’m still having to go to work and cover for others on furlough. I will get there in the end.
    AB Tools Brake Pipe Flaring Tool Professional In-situ 3/16" SAE Hand Held FL29 https://www.amazon.co.uk/dp/B01M4RC2..._AzHXEbNVET9PS
    Cheers, Martin.
  6. #6 Re: Brake pipe flaring.
    Exeter
    1,232
    Hi Martin. Thats great thanks. It makes a very neat and symmetrical flare. Will also avoid the nasty clamp marks around the pipe that I get with mine. Peter.
  7. #7 Re: Brake pipe flaring.
    Jul 2016
    608
    Whilst spending an hour or so working on the front brake pipes this evening I just noticed the trunion rubbers and bushes are perished and split.
    Beggar it another job to strip down to replace, these were new and never been on the road. Grrr.
    Can I get just the rubbers and bushes or a case of buying both trunions again.
    Cheers, Martin.
  8. #8 Re: Brake pipe flaring.
    SE London
    2,191
    You may be able to find a suitable track rod end universal gaiter
    https://www.ebay.co.uk/i/37304001207...SABEgJxYPD_BwE
  9. #9 Re: Brake pipe flaring.
    Jul 2016
    608
    Thanks Ben,
    Will have a measure up. The bushes On both sides have perished as well so will need to source a set of those.
    Cheers, Martin
  10. #10 Re: Brake pipe flaring.
    Exeter
    1,232
    Hi Martin. Ball joint boots will probably have too small a hole. The Triumph TR sports cars had similar fulcrum lower steering swivel. Have a look at Triumph TR4 seals below. Peter.
    https://www.moss-europe.co.uk/catalo...oup=&q=680-760
