Speedo Cable
  • Speedo Cable
    Hi folks. Finally after being off the road for nearly 30 years I got the Berlinetta Mot’d and on the road but the speedo doesn’t work. I have traced the fault to a broken cable. My car has a type 9 box in it but the speedo has a screw end. When I look for a type 9 speedo cable it has the correct gearbox end but has the plastic clip on the other end which is not the correct one for the actual speedo in the car. Will I need to get one specially made or is there a correct cable out there for them?
    Thanks.
    Re: Speedo Cable
    We have used Speedy Cables in the past.
    Liz
      Re: Speedo Cable
      I've used Speedy Cables too. Can't fault their cables, but Speedy it wasn't! Gareth.
      QUOTE=lizbillings;53225]We have used Speedy Cables in the past.
      Liz[/QUOTE]
        Re: Speedo Cable
        Sent them an email to see if they can help. Thanks.
          Re: Speedo Cable
          I hope you included pictures to help them?
            Re: Speedo Cable
            Will wait on their reply then send them pics mate. I have found a few on auction sites that fit the ford Zephyr mk1 which has the ford mushroom type on one end and the smiths screw end on the other but unsure if it will fit my Veglia Borletti speedo. That is a screw end too.
              Re: Speedo Cable
              Congratulations on getting MOT. Nice to have another back on the road.
              Liz
                Re: Speedo Cable
                Thanks.
                  Re: Speedo Cable
                  Nice one on getting the Berly back on the road. I have one on the back burner myself. Regarding your speedo cable. I have had similar in the past from Speedy Cable.
                  You should not have any problem.
