Results 1 to 10 of 17
Thread: size of battery in A/H
  1. #1 size of battery in A/H
    Aug 2015
    23
    I am wondering what size of battery to get for my 2 L DOHC Cabrio it looks like it needs 60A/h but that looks like a tight fit in the box
    Any suggestions would be very welcome
    Many thanks
    Nigel
  2. #2 Re: size of battery in A/H
    Jan 2018
    Bideford, Devon, UK
    97
    Not sure where your battery fits in the Cabrio, but here are flics of the Hunter installation. This battery is a Bosch S4-004 (12v)! 60A/H 540A [CCA]? which turns the 2.3 DOHC over much better than its knackered predecessor did.
    It is marginally taller, needing a little taken out of the bonnet hinge, partly due to me fitting a rubber sheet/gasket under the battery to protect the bulkhead moulding.
    www.thebatteryshop.co.uk - £72 delivered
    Last edited by kahawi; 03-08-2020 at 01:35 PM. Reason: Added Battery type number and removed http://
  3. #3 Re: size of battery in A/H
    1,068
    Battery size 063 is one size that has been used
  4. #4 Re: size of battery in A/H
    Aug 2015
    23
    Many thanks l will see if l can get one that size to fit N
  5. #5 Re: size of battery in A/H
    Aug 2015
    23
    Thank you for your repl
  6. #6 Re: size of battery in A/H
    Aug 2015
    23
    Whew I am glad I looked at your pictures again before ordering thank you
    I think I need to go and scratch my head again
    Nigel
  7. #7 Re: size of battery in A/H
    High Wycombe, Buckinghamshire
    2,011
    With this little baby you don't have to worry about size.
  8. #8 Re: size of battery in A/H
    Nov 2019
    32
    what is that!!??
  9. #9 Re: size of battery in A/H
    Jan 2016
    Rugby
    330
    Quote Originally Posted by marlin munroe View Post
    what is that!!??
    I believe that's a high A/H motorbike battery, a lot of the Lotus 7 facing fraternity use them as they are both small and reliable, plus I believe they are solid state so you can pretty much mount them how and where you want. On my wish list.
  10. #10 Re: size of battery in A/H
    2,011
    Its the battery in my Marlin. Powerful, reliable and small. This has been my battery of choice for two years now and the car starts on the button and is around the same cost as a standard battery.
    Can even be oriented upside down.
    Great battery and don't know why modern cars don't use them.
    what is that!!??
