Brakes - Single or dual circuit?
  • Brakes - Single or dual circuit?
    The Marina roadster I have just started to rebuild has the original single circuit brakes.
    For safety I would like to change to dual circuit but so far I have failed to find a tandem master cylinder. They seem to be like hens teeth.
    So the questions are:
    Are there any downsides to dual circuit? I know that the dual circuit brakes on a Spifire have a dreadful reputation...
    Where might I find a master cylinder? I have tried all the usual places with no joy.
    As I understand it the bore of the non servo master cylinder is 0.7" (the servo one is 0.75"). Can anyone confirm that?
    At this stage I don't want to consider using a master cylinder from another vehicle, with the associated hassle of modification, as I see some others have done.
    I am also not currently considering a servo although that might change!
    Cheers Robin
    Re: Brakes - Single or dual circuit?
    Check out 'Car Builders Solutions' They have lots of info.
      If it were me, I would go with a dual master cylinder setup using a servo delete solution like the one from compbrakes.
      CUSTOM REMOTE UNIVERSAL BRAKE BIAS PEDAL BOX KIT [HYDRAULIC - SERVO REPLACEMENT] DUAL CYLINDER [STD KIT] STANDARD BOX KIT INCLUDES – CUSTOM BOX PLUS - [2 X MASTER CYLINDERS, SWINGING PIVOT, CLEVIS, FIXINGS & BALANCE BAR]
      You would need to upgrade your pedal box to one that was designed to take a servo if yours is a non-servo type.
        I'm considering updating mine as well. I found that a TR6 servo and master cylinder will fit, or at least I found a reference with pictures of such an installation in the Morris Minor forum where the owner was upgrading to a Marina pedal box of all things. The page can be found here. I'm going down the route of building something like this to get bias adjustment as well as future proofing the installation
          I've just read that a master cylinder with servo from a Austin Allegro 73-75 bolts straight on and its dual circuit. Gleaned from Fast Marina site.
            Two different beasts
            There are tandem master cylinders - so if one circuit fails you still have the other
            And dual master cylinders where you can have one on each "end" - and change the brake bias front/rear
            As all Marlins have radically different weight distribution to their donor cars IMHO you NEED the dual type so that you can move the brake balance to suit your car
              My Roadster is over braked on the front and a suggestion was made to fit a pressure reducer in the font line to balance it. Car Builders IIRC.
                Hmm that's interesting. What is the configuration of your car?
                Cheers Robin
                  Interesting view. The problem is that cars with adjustable brake bias are not road legal in the UK I believe. They are certainly not allowed in the IVA.
                  Cheers Robin
                    Robin is correct. However if you use dual cylinders and find the best ballance then weld the adjustment then it will pass as it won't be adjustable....
                      It’s worth having a chat with the guys over on the Marina forum, FastMarina.......
                        Whether a Roadster is overbraked or not on the front axle is not the question. Robin clearly wishes to fit dual circuit brakes for safety reasons and at the moment is unable to source the correct master cylinder.
                        So guys, what are the solutions without resorting to extensive mods to pedal box etc
                          Cheers Robin
                          My car is not "adjustable" - except by replacing the balance bar - I did some calculations and track testing showed it to be pretty good so I have left it as it was
                          I intend using the same theory on my Marlin
                            Do you have such a thing as IVA in NZ?
                            for a new build to be properly registered in the U.K., it’s mandatory. Once registered, you can do what you like, provided you don’t mind driving an illegally modified car, and are not caught.
                              My suggestion would be to make sure that your rear brakes are functioning at their best.
                              The alleged Marina auto-adjusters are notorious for not auto-adjusting.
