Handbrake help
  • Handbrake help
    How does the Marina handbrake work?
    I have the axle with two levers sticking out of the backplates
    And that is ALL
    Sorting a handbrake from something or other for the bit you pull is not too difficult - but what is supposed to be on the axle??
    I assume there should be something that connects the RHS and LHS levers together and that the handbrake cable pulls together
    I have a Marina manual - its got a section on brakes but nothing on the damn handbrake
    What do the missing bits look like and how do they attach to the axle - if they do
    Re: Handbrake help
    Two pics Duncan. It's a "T" cable and rod with a sort of equaliser movement in the middle
    A pic of the cable assy would help but I don't have one
    Pics not brilliant, they were taken to show the shockers in their inverted position
    and then with plastic anti dirt covers
    Hope they help
    Rgds DC EDIT Try Google or ebay UK, found these two pics
      Re: Handbrake help
      And that is ALL
      My first response was to be ‘badly’ the autoadjusters were notorious for no auto adjusting, people have a habit of greasing them, attracting dirt and dust.
        Re: Handbrake help
        Thanks guys that is really helpful
        I do have a bit welded onto the axle casing - with a bolt seized and broken off in it!
        The brake slave cylinders do not have the auto adjust - probably a good thing
        I will see if I can buy some Marina parts - but I may be better off just making something
