Can I change a Q plate to age related?
  • Can I change a Q plate to age related?
    Hi I am the custodian of a Marlin Roadster that was built by my dad. I have managed to evade the archivists thus far although I am in the process of compiling a dossier for their benefit.
    I know at the time of registration my dad was keen to avoid being given a Q plate but that is what happened. I would now like to try and get it on age related plates. I realise there will be disadvantages to this as the emissions will be more than visual at the MoT. The advantage would be free road tax in the near future.
    I have all the original build documentation and submissions to the DVLA summarising the source of all the components. The car was built using the running gear suspension and steering rack and loom from the Ital donor. I am sure this complies with the 2 major components and obviously it was built on a brand new chassis. This means it complies with the age related plate requirements shown on the government website (see image).
    Does anyone have any direct experience of this? Is it achievable? If anyone has achieved this what was your method?
    Re: Can I change a Q plate to age related?
    ....and when you are ready the archivist will be delighted to hear from you on his home email
    I will let others wiser than me answer your query.
    DC
      I'm assuming that the DVLA site is stating the situation for new builds and the consequent IVA test. I was led to believe once a 'Q' registration had been allocated there was no way back.
        I seem to recall that some have managed to get it changed, but you have to have all of the documentation to hand to prove that it should have had an age related plate in the first place.
          As far as we know once a Q always a Q. Don't think you can put personal plates on either. However things may have changed over the years.
            As far as I'm aware, no club member has yet succeeded in changing from a 'Q' plate to an age related one but I could be wrong. Its certainly worth a try and, if you manage it, please let us know how.
              Thanks for the input folks. I have done as much research as I can. It is my intention now to write to the DVLA with my supporting information. I don’t think I will bother with progress reports on here. What I will do is report my conclusion and if successful, the steps taken to get there.
                if you have the V5 logbook for the donor car, you might have a lot more luck. Just having it’s registration number is not enough.
                  The V5 for the donor was submited to the DVLA with the V627/1.
                    I hope you kept a copy. It all helps if there are problems.
                      I do not wish to put a damper on this but I do not believe any one has ever managed to get a number changed from a Q I think what Andy is remembering is that some members managed to get their Marlins registered correctly to show Marlin on the V5 where before they were recorded as Morris, Ford or whatever. With age related your V5 will also show actual year of construction even though the reg number is an earlier year. As Liz says once a Q always a Q and cannot even be changed for personal plates.
                      I think that perhaps when your dad reg the car there may have be no option at that time to have age related. At that time you either got keeping the donor number or a Q as I remember. The age related option followed after this period, perhaps around SVA time. However there is always a first for everything so I wish you good luck.
                        My understanding has always been the same...i.e. once a Q always a Q...which has it's benefits come the MoT.
                        I know that back in the day the various regional DVLA offices (when such things existed) applied their own varying interpretations of the rules. In my case, Birmingham, they allocated a Q even though all major components were from the donor and the documentation was all there; whilst in other areas the original registration was carried over.
                        I still have copies of all the original documentation & submissions, plus the donor is still on the DVLA database, so I will be interested to see the outcome of this. I'm not really bothered about having a Q-plate , but if it could be changed without opening Pandora's box (IVA) then I'd certainly think about it.
                        Good luck & keep us posted..!
                          Hi getafix
                          Did you get anywhere with this? I'm in a similar situation though I was the builder, not my dad!
                          It seems unfair that people who got age-relate plates back in the 80s are now running around as "historic" vehicles!
                          Andy
                          Q634HCP
                            Originally posted by AndyBeck View Post
                            Hi getafix
                            Andy
                            Q634HCP
                            Unfair is the default position for the DVLA.
                            I am in a long standing saga with them being pushed from pillar to post.
                            The challenge is finding one person that is willing to understand yiur problem, but then you get kicked off, have to explain the problem all over again, and it’s impossible to talk to the first person who understood the problem.
                            The problems get bigger every year as they demand back tax that was not yiur fault.
                              Hi, no. In the end I lost my enthusiasm and just left it.
