Results 1 to 7 of 7
Thread: Serial number position for gearbox and rear axle please
  1. #1 Serial number position for gearbox and rear axle please
    54
    I am at present filling out a form for the dvla and need to supply these numbers could someone supply me with there locations .
    I am refurbishing my garage/workshop at present and can not get much access as the car is covered with loads of bits.
    Phil
  2. #2 Re: Serial number position for gearbox and rear axle please
    3,349
    BL, or whoever, never serialised the gearboxes to my knowledge.
    There are numerous iterations of the basic Triumph casing, not just in gear ratios, input shafts, reverse gear idlers, the list goes on.
    each individual gearbox after 50+years is really best classed as unique, who knows who has looked inside, strip it down, before buying spares.
  3. #3 Re: Serial number position for gearbox and rear axle please
    54
    Thanks Steve, I thought that may be the case, the gearbox has overdrive which points to it being a Triumph unit althouh I do recall reading a few decades ago that you could get a Marina with OD as an option.
    Cheers Phil
  4. #4 Re: Serial number position for gearbox and rear axle please
    3,349
    Quote Originally Posted by phild View Post
    Cheers Phil
    OD was never a standard option on a Marina or Ital.
    That would not preclude a reasonable mechanic from retro fitting a Triumph OD box after the first purchase but it will not be tagged with a serial number so still no hope with DVLA.
  5. #5 Re: Serial number position for gearbox and rear axle please
    Apr 2018
    Southland - NZ
    86
    If the DVLA requires "serial numbers" then you can add them
    Just make up some suitable numbers and stamp them on the castings
  6. #6 Re: Serial number position for gearbox and rear axle please
    3,349
    Quote Originally Posted by duncan View Post
    I get the impression, but stand to be corrected that phild is heading towards an IVA test.
    It’s not the time to play silly games that could scupper his plans.
  7. #7 Re: Serial number position for gearbox and rear axle please
    South Somerset
    575
    I seem to remember that when my Cabrio went through IVA I put N/A for gearbox and differential numbers. But that was 11 years ago and I can't find the copies of the paperwork I filled out.
