Rear Axel ID
  • Rear Axel ID
    My Marlin just failed the MOT on a rear wheel bearing. I know mine has the Morris Marina 1800 engine and assumed the running gear was also Morris Marina. Is there any way to ID the rear axel to ensure I buy the right bearing? Can post pics later if that would help?
    Many thanks in advance.
    Kelton
    Re: Rear Axel ID
    Search Steve Green's thread on rear hubs 7/6/2012
      Re: Rear Axel ID
      Thanks.
      There are subtle differences depending on the year of the donor car.
      There is no external visual difference between the two, particularly seals, so you will have to take them apart.
      There is lots of info if you follow the link in my forum signature, the document you will be looking for is here or there
      Parts are generally available from Rimmer Brothers and are identical to those from a Dolomite (not the sprint) so you can pick part numbers from there.
      In my Archive you will find parts lists, and workshop manuals to guide you through the process.
      Not wanting to scare you off but removing the hub and the bearing and then refitting usually requires a 20ton press. I had an agreement with my local garage so I went prepared with an extra large box of tea bags a bag of sugar and a biscuit selection, a tin of Quality Street should help you along the way.
        Re: Rear Axel ID
        Thanks very much. I think I’ve found the bearing!
        Yes, I was worried that it might be a difficult job. The garage that MOT’d the car wen’t interested in doing it at all. Better get myself tea bags and biscuits and visit a few local garages!
        Thanks again.
          Re: Rear Axel ID
          Thanks again.
          Presumably at this stage you don’t know which of the two sizes of oil seal you need and you have not got the paper gasket.
          All the necessary replaceable parts usually came with a bearing kit.
