Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: Rear axle - disintegrating spring mounts
  1. #11 Re: Rear axle - disintegrating spring mounts
    club member Club Member andyf's Avatar
    Sep 2014
    Yateley, Hampshire
    806
    No I haven't but it does seem from casual inspection that they could be and as you say they are relatively common. it sounded like you are planning a significant change in which case switching springs might be feasible.
  2. #12 Re: Rear axle - disintegrating spring mounts
    club member Club Member FranklinLeicester's Avatar
    Leicestershire
    326
    Going back to the U bolt problem, if NTG can’t oblige try sandersonleafsprings.co.uk They invite you to ask them for help with non standard u bolts.
    Franklin, Leicester
  3. #13 Re: Rear axle - disintegrating spring mounts
    Aug 2020
    37
    i hve some springs
  4. #14 Re: Rear axle - disintegrating spring mounts
    club member Club Member kolmershlagjp's Avatar
    Dec 2015
    avignon {sud de la France]
    142
    have you found the u bolts for marlin roadster i would like to buy them thank you
  5. #15 Re: Rear axle - disintegrating spring mounts
    3,404
    Quote Originally Posted by stewart 27 View Post
    i hve some springs
    Have you managed to identify the source of your springs, there are many alternatives available through the Marina/Ital range.
    it is best to avoid the stronger springs unless you can match them to the different torsion bars.
    The relevant info is inevitably archived on Keepandshare for reference.
  6. #16 Re: Rear axle - disintegrating spring mounts
    Moderator Club Member
    Derby
    1,530
    A couple of possibilities
    Demon tweaks have extended ones for Ford - 65 mm between legs
    Sanderson Leaf springs or Owen springs both have a range of 'U' bolts ,probably worth a call
