Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: Stripping alloy wheels
  1. #11 Re: Stripping alloy wheels
    Chester
    412
    Something else I'm doing is changing the old Mountney steering wheel to a 9 hole Astali wheel. Thought I'd just check I can get the old wheel off as the steering nut could be done up tight and a puller might be needed to free the boss off the splines and taper. Took off the horn button cap to reveal that the big nut was finger tight and no lock washer fitted and the wheel just lifted off once the nut removed! It's been like that since I got the car and passed numerous MOT's and never given a hint of being loose! Could have ended in tears...suggest you check yours!
    Gareth
  2. #12 Re: Stripping alloy wheels
    Chester
    412
    Well, that's the wheels done, windscreen frame done and a new steering wheel as well. She scrubs up well!
  3. #13 Re: Stripping alloy wheels
    1,652
    A nice shiny day and a nice shiny car as well....must be summer soon
  4. #14 Re: Stripping alloy wheels
    High Wycombe
    1,266
    That is a stunning machine...
  5. #15 Re: Stripping alloy wheels
    721
    Wow! Amazing!
    Well done
    Liz
  6. #16 Re: Stripping alloy wheels
    By Douarnenez Bay Finistere
    576
    So, how did you strip the wheel rims?
  7. #17 Re: Stripping alloy wheels
    Chester
    412
    Quote Originally Posted by Tony Stott View Post
    I used Nitromoors in the end Tony. Soaked on thick for about a hour then power washed off the lacquer. If my paint job flakes it will be easy to touch up or I could pay for a proper job. A proper job will have to wait as too many other things to pay for first!!
  8. #18 Re: Stripping alloy wheels
    576
    Ok, thanks for that, I have some tatty alloys on my daily driver, which have some diamond cutting on them, thinking of stripping them and not bothering with the cut areas just to get an idea of the changed effect!
