Results 1 to 8 of 8
Thread: Marina rear axle.
  1. #1 Marina rear axle.
    Nov 2018
    6
    I acquired a Triumph /Marina hybrid Roadster chassis and panels last year.
    Would any member be able to help me with sourcing the rear axle set up.
    They seem to be as rare as hens teeth.
  2. #2 Re: Marina rear axle.
    3,422
    Quote Originally Posted by rex3644 View Post
    This will help a great deal.
    https://kvisit.com/S1Mb2AQ
  3. #3 Re: Marina rear axle.
    Aug 2020
    51
    i have a rear axle
  4. #4 Re: Marina rear axle.
    Nov 2018
    6
    How much do you want and where are you based please?.
    Could I come and collect?
  5. #5 Re: Marina rear axle.
    Aug 2020
    51
    dn21 4uh 07810204120 give me a call
  6. #6 Re: Marina rear axle.
    3,422
    What is the problem with your existing diff?
    there are two different ratios for the Marina, a mismatch will be a disappointment.
    I strongly suggest reading the document that I shared. Swapping the axle is easy enough but you don’t know the condition of the axle or the brakes you are fitting. Swapping the diff centre, once you know what it is, is a much quicker job.
    My advice is to take it one step at a time, and get it right.
  7. #7 Re: Marina rear axle.
    Nov 2018
    6
    Hello Steve.
    I don't have any axle at the moment. the chassis is a Triumph Marina hybrid.
    My proposed donor is an old Vitesse based Spartan so I should be able to change the crown wheel and pinion if need be
    thanks for your help.
  8. #8 Re: Marina rear axle.
    3,422
    Hello Steve.
    Changing the crownwheel and pinions as individual parts is not really a job for the home mechanic, it’s a more specialist job and requires specific tools. Many have tried and the parts end up in a box under the workbench and not in the differential housing.
    A second hand axle, probably still with the 1970’s oil still in it is an unknown goood luck
