Results 1 to 4 of 4
Thread: Idle Air-Control valve, testing:-
  1. #1 Idle Air-Control valve, testing:-
    Jan 2018
    Bideford, Devon, UK
    97
    Ford 2.3ltr DOHC-16valve fuel-injected.
    Idles at about 12-1300 rpm, which seems a bit high? Otherwise runs fine.
    Does anyone have experience of testing the idle air-flow valve? It’s a two-pole device, so I assume 5-12volts will open it and either a spring return, or reversing the power closes it again?
    Too much ‘electrickery’ under the bonnet for my liking, but I’m wondering if I have a slight leak, either in the valve seating or the jointing gasket, would that cause higher idle revs?
    Cheers, Colin B
  2. #2 Re: Idle Air-Control valve, testing:-
    Mar 2013
    Fife, Scotland
    607
    Whilst I am not familiar with that particular Idle Control Valve, ones on other engines respond well to a clean with the likes of WD 40. The part of the valve that slides or rotates gets gummed up.
  3. #3 Re: Idle Air-Control valve, testing:-
    Suffolk
    497
    I had a similar problem with the 8valve DOHC engine with the idle speed fluctuating between about 12 - 1500rpm. Cleaned the idle control valve but made no difference. Then replaced it with a new one (expensive!) and again made no difference. On advice from someone (can't remember who) I replaced the Throttle Position Sensor (TPS) and it solved the problem. Don't ask me how or why!
  4. #4 Re: Idle Air-Control valve, testing:-
    Moderator Club Member
    Derby
    1,544
    You should be able to feel a slight vibration through it with the engine running, if you can then it's likely ok . Air leaks as usual can be checked by spraying brake cleaner or similar around the valve. If those items check out ok then I would go with Geoff's suggestion of TPS .
    The one I had on my BMW engined Cabrio could be rotated to some degree for adjustment purposes and seemed quite critical in getting it right.
