Results 1 to 4 of 4
Thread: Waterproofing bonnet piano hinge
  1. #1 Waterproofing bonnet piano hinge
    Jun 2020
    9
    I’ve got my Cabrio out of storage this week and it’s back on the drive with an unsightly cover on it. One of the reasons for the cover is that the bonnet hinge will let a bit of rain to drip onto the engine bay.
    Is there a way to make the hinge a better seal?
  2. #2 Re: Waterproofing bonnet piano hinge
    Exeter
    1,272
    Quote Originally Posted by charlh94 View Post
    I would be thinking of U-section plastic or rubber to make a “gutter”. As the hinges, or rather the fold of the bonnet at the hinge, vary between different Cabrios and Hunters, then that would determine the eventual size and shape of the cross section. Even folded rubber sheet may work? As the bonnet slopes down towards the front I would try and extend it at that end to take any drips over the radiator into the nose cone area. Peter.
  3. #3 Re: Waterproofing bonnet piano hinge
    Moderator Club Member
    Derby
    1,530
    I have looked into this a few times both for Roadster and Cabrio but couldn't come up with a reliable solution, as in order to allow bonnet to open a much larger section than you initially think is needed. There is also the problem of how /what to attach to.
    There may be a fix , but I failed to find one that worked for me.
  4. #4 Re: Waterproofing bonnet piano hinge
    club member Club Member
    Jun 2015
    Kelsall Chester
    755
    For my Roadster, I am looking at using a piece of square aluminum channel fastened to one side of the bonnet angle, which should then overlap the angle on the other side. The theory is good but I haven't tried it, yet. A drain at the bulkhead end may be needed to stop water from being blown up the channel.
Tags for this Thread
