WANTED - Roadster rear body tub
  • WANTED - Roadster rear body tub
    I am rebuilding an early Marina based Roadster. I have a rear tub but it is the one with the top edge crudely riveted to an aluminium plate and supported by a hoop. Not the greatest of mouldings and not easy to finish well.
    I would like to fit one of the later body tubs with a return edge on the top. I am guessing it would be a fairly straightforward swap.
    So - does anyone have one for sale? I am based in Bedfordshire and happy to collect within a couple of hours drive.
    PS.I am looking for one WITHOUT a spare wheel well. :-)
    Re: WANTED - Roadster rear body tub
    call or email 07976 836374 [email protected]
      Email sent. :-)
        Still looking. The one that Danny offered me had a spare wheel well so wasn't suitable.
        Cheers Robin
          Cheers Robin
          Hi Robin
          I stand to be corrected, but I do no think the later rear tub with the return edge you are looking for was produced without the well.
          You maybe looking for something that does not exist.
          Could you not modify the one that Danny has by removing the well and re-fibreglassing? Or modify the one you have a create a return edge?
          Jon
            FWIW "Roadster Development doc" is on the "Marlin Histories" tab on the main website
              Aha - so it seems the spare wheel well is standard if you have the rolled top edge. I'll have to think again....
              Cherrs, Robin
                Originally posted by jon_cox View Post
                Hi Robin
                Jon
                You are correct it seems. Unfortunately my fibreglassing skills are not up to either of your alternative suggestions :-(.
                I'll have to think again it seems.
                  Hi I au the the rear tub you are looking for call me Andrew on 07831561121 anytime
                    Hi Andrew
                    Whereabouts are you? I am in bedfordshire and dont want to travel further than necessary...
                      did you get the rear tub you was looking for
                        No. It seems what I wanted doesn't exist. That is the later tub with the returned edge, but without a wheel well.
                        So at least for the moment I am sticking with the original tub which doesn't have the return but also doesn't have a wheel well.
                        Cheers Robin
                          I’ve often wondered about this as PKK had a no return no wheel well, then the car I had later had the return with the wheel well which got me thinking would be good to have a returned shell without the wheel well as carrying a spare nowadays is a bit redundant.
