Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: Help needed to identify the fuel tank in my roadster
  1. #1 Help needed to identify the fuel tank in my roadster
    Jun 2020
    3
    I am trying to identify the fuel tank currently in my Marina based Roadster. I believe it should be a Mk1/2 escort estate, but looking at pictures on line and in the build manual it doesn’t look the same.
    hopefully someone can identify it.
  2. #2 Re: Help needed to identify the fuel tank in my roadster
    club member Club Member andyf's Avatar
    Sep 2014
    Yateley, Hampshire
    807
    That looks like a custom tank to me
  3. #3 Re: Help needed to identify the fuel tank in my roadster
    club member Club Member David's Avatar
    High Wycombe
    1,275
    That’s what I was thinking, similar to the one I had made for PKK.
    - 4th owner of Q309 RNV, an early Cabrio built by Bob Copping, owned by Danny then Doug & Liz Billings for 16 years
  4. #4 Re: Help needed to identify the fuel tank in my roadster
    3,407
    Custom tank, not a Ford standard.
  5. #5 Re: Help needed to identify the fuel tank in my roadster
    Jun 2020
    3
    Thanks guys or should I say tanks, I thought it looked special, I guess I will need to get another made. Anyone know a good supplier, I don’t want an aluminium one as I trial so it need to be steel. I’m in Gloucestershire so anywhere near would be good.
  6. #6 Re: Help needed to identify the fuel tank in my roadster
    Mar 2016
    29
    Quote Originally Posted by siliconman View Post
    Is there something wrong with the tank? Can it not be repaired?
  7. #7 Re: Help needed to identify the fuel tank in my roadster
    Jun 2020
    3
    It’s got some rust on the hangers but the main problem is a big dent in the bottom, which may be possible to correct through the gauge hole. I would also like a gauge that works fitted
  8. #8 Re: Help needed to identify the fuel tank in my roadster
    Jun 2015
    Kelsall Chester
    761
    Now you want the fuel gauges thread. I cut the sender out of a Marina sender and silver soldered it to the ford pipe. Bending the float wire to suit. It reads right FSD empty to full.
  9. #9 Re: Help needed to identify the fuel tank in my roadster
    1,660
    P M sent...look top right under "Notifications"
  10. #10 Re: Help needed to identify the fuel tank in my roadster
    Jun 2012
    Sandbach
    254
    I have had a couple of tanks repaired over the years by Cropper & Jones 0151 356 0159 may not be ideal for you as they are in Ellesmere Port
