Results 1 to 10 of 14
Thread: Cabrio V8 cooling
  1. #1 Cabrio V8 cooling
    club member Club Member
    Apr 2021
    15
    Hi My newly acquired Cabrio has a V8 engine fitted. Just sorting a few things out before I get it MOT'd. At the moment it has the Marlin supplied radiater, which seems a little small, although I am toying with the idea of getting a custom made aluminium radiator made up.
    The car has an electric fan at the front of the rad and a cooling fan at the rear driven from the engine pulleys. Space is very tight between the engine fan and the radiator and the hoses etc in this area. I'm thinking as I have the electric fan do I really need the engine fan as well. I wondered what other Marlins with V8 engines have.
  2. #2 Re: Cabrio V8 cooling
    High Wycombe, Buckinghamshire
    2,011
    Although I am a Roadster owner, my old school mechanic gave me some good advice some years ago.
    I had removed my fan and just relied on the electric fan and had problems with overheating.
    He suggested that, as the under bonnet room was at a premium, the original fan was helping to dissipate the heat.
    I put the fan back on and have not had an overheating issue since.
    The long and short of it, I would leave it on.
    No doubt, others will have other ideas but this has worked for me on both my Toyota powered engine and my current Marina 1.3 based.
  3. #3 Re: Cabrio V8 cooling
    Exeter
    1,281
    Sounds about right. I read on a Landy off road forum that the mechanical fan contributed to engine cooling due to the constant flow of air over the alloy block and heads. Those guys tend to fit twin electric fans with a cut out switch for when they drive through 4ft deep puddles to save filling the engine compartment! So they loose the benefit of the mechanical fan.
  4. #4 Re: Cabrio V8 cooling
    Apr 2021
    15
    Sounds like I need to leave it on thanks all.
  5. #5 Re: Cabrio V8 cooling
    220
    Hi - I am amazed that there is space for the fan behind the radiator. The build manual says to remove it, and cut off the nose of the shaft. There is then only a small gap to the radiator. Do you have a smaller radiator which is set further forward, I wonder? It is generally believed that a fan works better by sucking rather than blowing, ie better behind the radiator. With that in mind I looked at fitting electric fans behind my radiator, but it was impossible. So I remain with a front mounted fan and an assortment of other devices to keep the temperature down. The Rover V8 is well known for running rather warm, so if yours is behaving, LEAVE WELL ALONE!!! Enjoy your car! Dave.
  6. #6 Re: Cabrio V8 cooling
    Apr 2021
    15
    The radiator is squeezed between the nose cone and the up rights on the chassis with no spare room. It misses everything obviously but it looks like the mechanical fan has had problems in the past. Most of the radiator cooling elements have been flattened but luckily its still watertight. I'll see how it goes I may get a new aluminium radiator made up.
  7. #7 Re: Cabrio V8 cooling
    725
    Suggest you get it MOT'd and try it. Just the weather for runs out now.
    Liz
  8. #8 Re: Cabrio V8 cooling
    Aug 2020
    42
    it coud be the size off the rad i have one that you can come and mesure
  9. #9 Re: Cabrio V8 cooling
    Dec 2014
    Somerset
    35
    Quote Originally Posted by slatept View Post
    If the radiator is damaged can the air still get through it?
    You may be surprised how far an engine can move forwards, distorting the mounts, under heavy braking.
  10. #10 Re: Cabrio V8 cooling
    Jan 2018
    Bideford, Devon, UK
    98
    If the fins have been flattened, it will limit the flow, for sure. One of the ‘tasks’ when servicing customers air-con was to ‘comb’ the fins to improve air-flow through.
