Results 1 to 10 of 18
Thread: Hunter rear springs
  1. #1 Hunter rear springs
    Jul 2021
    2
    I have recently acquired a Hunter, first registered April, 1995, chassis number T-4064.
    I need to replace the rear springs. Can anyone tell me what springs I require. The engine is a Ford Sierra
  2. #2 Re: Hunter rear springs
    South Somerset
    634
    My Cabrio uses standard springs from a 1989 Sierra 2.0 DOHC
  3. #3 Re: Hunter rear springs
    1,706
    Welcome to the MOC.
    Please contact me on the email as in Pitstop and I may be able to give you some background on your car
    Rgds Dave Cunnington Club Archivist
  4. #4 Re: Hunter rear springs
    231
    Hi
    Rear springs on Cabrio/Hunter are standard Sierra. With possible exception of Cosworth and estate, all Sierras used the same springs. They are readily available on ebay, but genuine Ford are non-existent. I bought some a couple of years ago, as the bump stops had disintegrated, and it seemed sensible to change the springs at the same time. I found genuine Ford bump stops! The ride height may need adjusting after the springs are changed, or they may settle. I'm still waiting for mine to settle! I think the springs can be changed by undoing the shock absorber and lowering the swinging arm, so not too difficult. Can't be sure, as I got the garage to do it, as my back doesn't like any heavy work!
    Enjoy your car - Dave
  5. #5 Re: Hunter rear springs
    Jul 2021
    2
    Many thanks for your responses. I had thought it probably would be Sierra springs. However there are several options on-line for different Sierra springs!!! Some appear to be much longer than others. I will probably go for the shorter springs.
  6. #6 Re: Hunter rear springs
    231
    The springs I bought were KYB K-Flex RA5190, if that is any help. I don't recall different lengths, but there are a lot of variables in springs, which can be used to balance one another out, ie length, diameter, number of turns, wire diameter, tensile strength. Would short springs be stiffer than long ones on average? In which case I'd opt for long on a light car like the Cabrio. If you think this is confusing, wait till you start on the front springs!!!!! Dave.
  7. #7 Re: Hunter rear springs
    502
    My Cabrio was purchased from someone who could not complete the car. It came with two sets of springs. I have always supposed them to be the donor Sierra’s and purpose made Cabrio springs. I am surprised to read that the donor springs are acceptable. The donor was an estate car so the lighter springs may have been from a saloon or hatchback.
    I have a vague recollection that specialist companies will make a spring tailored to your car, particularly useful for cars of the Lotus 7 variety.
  8. #8 Re: Hunter rear springs
    231
    The rear suspension on the Sierra estate is different to the saloon. If an estate is used as the donor, the rear swinging arms from a saloon need to be sourced. Front springs are not from the donor, and coil over shocks are used. From what I have seen, Marlin supplied whatever they could source for the front suspension, as there are numerous combinations of shocks and coils around. Some work better than others! There are several threads on here related to front coils and shocks, but I'm not sure a conclusion was ever reached as to the best combination. Dave
  9. #9 Re: Hunter rear springs
    Okehampton, Devonshire
    78
    Hi,
    Just seen the post. I used progressive springs from a 1989 2.o litre GLS cut down to 10 & 3/4 inches. Shortening from the bottom thicker winding end, so leaving the thinner "progressive" top of the spring. Gives a lovely comfortable ride under normal driving but is firm enough when driven hard. Hope this helps. All the best Mike.
  10. #10 Re: Hunter rear springs
    Exeter
    1,311
    Thanks Mike for this info. I fitted aftermarket progressive rear springs and Boge gas dampers to my 1987 2.0GL Sierra and it transformed the comfort and handling. I was sure that one of the Sierras had these as a neighbour had them on his, so at last I now know which model. I have thought for some time that my Hunter would benefit from these springs to give better control of the rear end over yumps and avoid the silencers catching the ground when fully laden. Did you try them on your Marlin before cutting them shorter? Doesn’t that make them feel stiffer? Peter.
