Results 1 to 6 of 6
Thread: A continuing project, Q399 Hybrid Roadster V8
  1. #1
    1,721
    Be good to see this back on the road
    eBay item number:164985730872
    Attached Images Attached Images
  2. #2
    club member Club Member David's Avatar
    High Wycombe
    1,327
    Re: A continuing project, Q399 Hybrid Roadster V8
    Was just looking at that!
    - 9th owner of T693 SSC a factory built Ford based V8 Sportster
  3. #3
    63
    It would be good to get a proper look at the rear axle set up! No leaf springs, coil over shocks, sway bar and radius arms. Thats the sort of setup I have been thinking of for when I can eventually can get restarted on my marlin. I have been looking to do a version of the locost design, but it would be helpful to see this setup.
    Cheers Phil
  4. #4
    club member ian944's Avatar
    Aug 2021
    9
    Quote Originally Posted by dcunn View Post
    I've bought this, and first task was to join here
    The guy had two, so I've bought both, The V8 Turned up Monday and is now tucked up one end of the garage, a van load of boxes turned up yesterday, never seen so many spiders..... The second hopefully is being picked up tomorrow (hopefully)
    It looks like there is a lot of work to do on both of them.
  5. #5
    Suffolk
    529
    Welcome to the club. You will find a wealth of knowledge and experience on this forum if you need it during the re-build.
  6. #6
    Aug 2021
    9
    Thanks for the welcome ggrum.
    I've started a thread in the new members area which shows the interesting condition the cars are in currently.
    Lets hope I can get at least one of them back on the road.
    Regards,
    Ian
