I found this which looks to be well informed from High Powered Media (HPM) written in 2014. HPM is an American website that purports; “Fact not fiction. Science not speculation. Engineering publications written by engineers, for engineers.”
https://www.highpowermedia.com/Archi...nk-and-ethanol
Although light, aluminium is a highly reactive metal that relies on an oxide layer for protection against its corrosion. This oxide layer occurs naturally, and the low levels of ethanol such as E10 (10% ethanol, 90% gasoline) or the 5% ethanol blend often found in Europe are usually not a problem. The problem occurs principally when the ethanol content in the fuel is increased beyond these levels. The issue, although complex, generally centres on the presence of water in the fuel.
Corrosion behaviour of aluminium alloys in ethanol fuels
http://www.process-design-center.com...ol%20Fuels.pdf
This 9 page report looks like a very comprehensive analysis (I didn't read it all). It is full of pictures of surface structures and graphs. I’ve copied an excerpt from the last paragraph of a lengthy conclusion (I'm not sure about the nickel coating):
The chemically deposited nickel layer exhibits a very good resistance to alcohol fuels, independent of temperature and water or ethanol content. The mass loss was only a few hundredths of a percent. Macroscopic and microscopic observations of the surface of the coated specimens revealed an undamaged material free of corrosion products.
So I guess the aluminium should be alright but any sealants, rubbers, etc will be suspect.
