Results 1 to 10 of 11
Thread: Morris Marina Leaf Spring Shackle Pin
  1. #1 Morris Marina Leaf Spring Shackle Pin
    club member Club Member
    Feb 2020
    Bedfordshire
    140
    Wanted - as in the title.
    One of mine has stripped threads rendering it useless. From all my searching so far they seem to be unique to the Marina.
    They also seem to be made of some hardened stuff so not so easy to get a 1 off made.
    Cheers, Robin
  2. #2 Re: Morris Marina Leaf Spring Shackle Pin
    Exeter
    1,311
    Quote Originally Posted by martinclan56 View Post
    Cheers, Robin
    Is this any use?
    https://www.ebay.co.uk/itm/372762572594
    Peter.
  3. #3 Re: Morris Marina Leaf Spring Shackle Pin
    Moderator Club Member
    Derby
    1,581
    Try Owen Springs
  4. #4 Re: Morris Marina Leaf Spring Shackle Pin
    Feb 2020
    Bedfordshire
    140
    Unfortunately not. The shackle pin is a thingy with a thread at both ends. I'll post a picture tomorrow.
    Cheers Robin
  5. #5 Re: Morris Marina Leaf Spring Shackle Pin
    Exeter
    1,311
    Cheers Robin
    Something like these then?
    https://www.morrisminor.org.uk/parts...&page-size=all
    Austin Healey
    https://www.ahspares.co.uk/austin-he...lowernuts.aspx
    I would start by noting the key measurements of yours (imperial or metric) and the thread type (UNF, BSF, metric etc). Then search for the same dimensions, even if for a different car. If the threads type are different to yours just get the appropriate nuts to fit. As long as the diameters are the same it will do the job! Peter.
  6. #6 Re: Morris Marina Leaf Spring Shackle Pin
    Jun 2015
    Kelsall Chester
    776
    DW car spares in Liverpool may be able to help, 0151 933 9439. They seem to have lots of Marina new & S/H spares. No connection, nice people.
  7. #7 Re: Morris Marina Leaf Spring Shackle Pin
    Feb 2020
    Bedfordshire
    140
    Austin Healey
    Yes - that's the sort of thing. I am pretty sure that the moggie one is too short as the leaf spring on a moggie is only 1.5" wide and it's 2" on a Marina.
    As soon as I can get Flickr to behave itself I'll post a picture.
    Cheers, Robin
  8. #8 Re: Morris Marina Leaf Spring Shackle Pin
    Feb 2020
    Bedfordshire
    140
    Here is the Marina shackle pin.
    shackle pin by Robin Martin, on Flickr
    To the left is my first attempt at a substitute using a 3/8 unf bolt and a spacer made from stainless tube. The bolt is a slightly looser fit in the spacer than I would like but it would probably be OK if I can't track down the real thing.
    Cheers, Robin
  9. #9 Re: Morris Marina Leaf Spring Shackle Pin
    club member Club Member b_caswell's Avatar
    SE London
    2,232
    Its possible the same as a Morris Minor but you would need to check about the dimensions.
    Pays to read the above posts first just spent half an hour trying to find the MM parts book.
  10. #10 Re: Morris Marina Leaf Spring Shackle Pin
    May 2016
    179
    In addition to the above , never compared but check out Escort MK2, Ford Capri rear shackles , MGB and also for Triumph Dolomite's.(Moss Europe, Rimmer Bothers , MGB Hive). Any rear spring of the same width will be a possibility if the shackle diameter is correct for your Bush.
    eg:
    https://www.moss-europe.co.uk/shop-b...t-1962-80.html
    I would have thought that the item is initially manufactured and then hardened by heat treatments afterwards, so perhaps a small engineering shop could make you a pair?
