Results 1 to 10 of 15
Thread: Proximity of handbrake cable to rear dampers
  1. #1 Proximity of handbrake cable to rear dampers
    club member Club Member
    Feb 2020
    Bedfordshire
    169
    I have just trial fitted the rear axle, and all the associated bits and pieces, to my Marina based Roadster. My goodness it's heavy!
    I am a bit concerned with how close the handbrake cable is to the dampers. It seems to be worse on the drivers side with a clearance of only 1 or 2 mm. I think it could easily touch when the car is being driven - which I guess would be an MOT failure.
    Is this a standard problem and, if so, what have others done about it? In a worse case scenario I suppose I could extend the hand brake levers (the ones that pass through the brake back plate) by a few mm but that would be a real pain to do.
    The picture was taken with the handbrake cable slack, but even with it under tension, the situation doesn't improve significantly.
    Cheers, Robin
    PS - I am using Spax adjustables - perhaps they are slightly bigger in diameter than OEM dampers?
    hand brake cable by Robin Martin, on Flickr
    axle trial fit by Robin Martin, on Flickr
  2. #2 Re: Proximity of handbrake cable to rear dampers
    Moderator Club Member
    Derby
    1,613
    Seem to recall mine was very much the same when I built it, never caused any issues in the 12 years I had the Roadster.
  3. #3 Re: Proximity of handbrake cable to rear dampers
    Mar 2016
    Macclesfield, Cheshire
    429
    Mine's the same with standard dampers. As dogoncrazy says, not caused any issues and MOT inspector has not mentioned it over the years.
  4. #4 Re: Proximity of handbrake cable to rear dampers
    1,744
    Normal I believe, this was Q67 during rebuild.
    Robin you might like to think about reversing the top shocker bolts, the way yours are will make any future removal difficult !
    I originally did them as yours, then Ben suggested turning them round
  5. #5 Re: Proximity of handbrake cable to rear dampers
    club member Club Member kolmershlagjp's Avatar
    Dec 2015
    avignon {sud de la France]
    145
    hello
    can you tell me the brake cable you have to buy for a marina base roadster thank you?
  6. #6 Re: Proximity of handbrake cable to rear dampers
    Feb 2020
    Bedfordshire
    169
    It's the standard Morris Marina. Loads on Ebay (uk).
    Cheers Robin
  7. #7 Re: Proximity of handbrake cable to rear dampers
    Dec 2015
    145
    I bought a morris marina cable it was too small
  8. #8 Re: Proximity of handbrake cable to rear dampers
    Feb 2020
    Bedfordshire
    169
    Yes - I thought about that. But, unless I slot the mounting holes there simply isn't enough room behind the brackets to fit a nut. As it is I had to shave about 1mm off the bolt heads. I have just enough room to get a spanner in as it stands.
    Cheers, Robin
  9. #9 Re: Proximity of handbrake cable to rear dampers
    Feb 2020
    Bedfordshire
    169
    Quote Originally Posted by kolmershlagjp View Post
    Hmm - perhaps it was the wrong one. This is the one I have.
    https://www.ebay.co.uk/itm/234224591...MAAOSwITpg~Ch~
  10. #10 Re: Proximity of handbrake cable to rear dampers
    532
    Hi Robin
    I think your top damper brackets are the wrong way around. The build manual states the damper mounting holes should be closer to the outside as per the photo posted by dcunn above in post #4.
    please double check.
