Results 1 to 10 of 11
Thread: B series engine and overdrive gearbox
  1. #1 B series engine and overdrive gearbox
    club member Club Member
    Feb 2020
    Bedfordshire
    173
    Has anyone ever fitted the B series engine, in a Marina based Marlin, with an MGB overdrive gearbox?
    The engine/gearbox combo comes up quite a lot on Ebay and an overdrive box certainly is an attractive proposition.
    I realise it would need a new propshaft made up but would the overdrive box physically fit?
    Cheers, Robin
  2. #2 Re: B series engine and overdrive gearbox
    club member Club Member lil_red_roadster's Avatar
    Telford, Shropshire
    668
    It's been done a few times IIRC.
    However, the tunnel & floor will need adjustment to fit around it...it's quite a big (and heavy) unit.
    The other thing to watch out for is the input shaft has a larger diameter than the Marina box, so does not mate to a Marina B unless you are lucky enough to have an engine with the removeable insert in the crank.
  3. #3 Re: B series engine and overdrive gearbox
    1,754
    Martin, if you check Tech Tips, way back when, there were several useful Pitstop articles on differing gearboxes.
  4. #4 Re: B series engine and overdrive gearbox
    3,445
    It’s too late, but fitting a Ford Type 9, not impossible. No tunnel mods were necessary.
  5. #5 Re: B series engine and overdrive gearbox
    Derby
    1,614
    Why not a Mazda box on to the B series .
  6. #6 Re: B series engine and overdrive gearbox
    Telford, Shropshire
    668
    Quote Originally Posted by dogoncrazy View Post
    £2665 + VAT Unless you DIY it..!
    https://www.vitesse-ltd.com/products...21481998647379
  7. #7 Re: B series engine and overdrive gearbox
    Derby
    1,614
    True , but a reconditioned Type 9 will be close to a grand and then you still want adapter etc. A MGB box with overdrive will as already mentioned require the floor /tunnel to be modified and the footwell is already tight on room for the pedals.
  8. #8 Re: B series engine and overdrive gearbox
    I've successfully done this twice. It's a tight fit but it all works, the overdrive is very handy especially if you have a van axle and
    a low diff. New tunnel, new gearbox mounts, new floors, wiring and new prop. Job done.
  9. #9 Re: B series engine and overdrive gearbox
    Jun 2015
    Kelsall Chester
    796
    Simples!! if you are a Cornish Wrestler!
  10. #10 Re: B series engine and overdrive gearbox
    Feb 2020
    Bedfordshire
    173
    Quote Originally Posted by Cornish Wrestler View Post
    Thanks. Not worried about new tunnel and floors as I am making new anyway.
    I don't suppose you have any pictures?
    Cheers Robin
