Results 1 to 8 of 8
Thread: Non-starting problem
  1. #1 Non-starting problem
    club member Club Member nightsurfer's Avatar
    Oct 2018
    Cambridgeshire
    50
    Driving to work this morning, I thought at first something had broken off inside the silencer; very loud and a tinny sort of rattling when I tried to accelerate.
    Luckily there was a roundabout just ahead and at 6:30am not a lot of traffic on the back roads.
    I made it most of the three miles back, then 1/4 mile from home hit a red traffic light. The engine stopped.
    It took a minute or two to get it going again and I made it as far as the driveway where it stalled again.
    The engine (2L Pinto) appears to turn over OK without plugs fitted and I see a spark at the plugs (I have some of those red AccuSpark tester things).
    Disributor cap, rotor arm, spark plugs and leads all replaced. Still no joy.
    I have an Accuspark electronic ignition distributor and run on BP Ultimate unleaded.
    The battery is fully charged using a trickle charger.
    Does anyone have a suggestion as to what I should try next?
    Thanks.
  2. #2 Re: Non-starting problem
    club member Club Member angusgrooby's Avatar
    Peterborough
    108
    It sounds like timing to me Alan, have you checked the cam has not jumped a tooth or the dizzy bolt has come loose altering the timing.
    You don't mention anything about fuel are you getting fuel to the carb? have you taken a plug out after cranking to see if it's wet with fuel?
  3. #3 Re: Non-starting problem
    Oct 2018
    Cambridgeshire
    50
    I checked the timing and it appears to all be correct, the rotor arm, timing marks and #1 piston all seem to be where they should be.
    Then I tried putting a bit of fuel into the carb by twisting the accelerator linkage a few times that seemed to work fine.
    I'm wondering if fuel might have anything to do with it. I have always used Shell premium, but the last two fill ups I used BP Ultimate (1/2 a tank each time).
    I'm going to get a gallon of shell and pour a little into the inlet manifold to see if that fires the engine.
    Not sure if bad fuel would have caused the tinny knocking in the exhaust.
    I also held my hand over the exhaust as I cranked the engine and there seemed to be pressure from the engine.
  4. #4 Re: Non-starting problem
    club member Club Member jon_wilkinson's Avatar
    Mar 2016
    Macclesfield, Cheshire
    432
    Check your rubber fuel hoses. Had a crack in one of mine and the pump couldn't draw from the tank.
  5. #5 Re: Non-starting problem
    3,443
    Quote Originally Posted by jon_wilkinson View Post
    If your hoses and pump are not ethanol compatible, maybe that’s the problem.
    for parts, check Buren’s who have parts for pumps and carburettors that are compatible.
  6. #6 Re: Non-starting problem
    Oct 2018
    Cambridgeshire
    50
    Thanks both. I'll check the hoses tomorrow, but there was plenty of fuel at the carb and in the (see through) fuel filter. The float chanber was also full.
    They've been on the car for three years (1200 annual mileage) and up until the last two fills, I have always used Shell V-power.
    I called into Quest Brothers Classic Cars in St Ives (Cambs) tonight and spoke to Paul. He has suggested checking the valve clearances and compression, so I've ordered a compression tester, which should arrive next week.
  7. #7 Re: Non-starting problem
    Feb 2016
    17
    The noise from the silencer may indicate you have a loose baffle. This may be blocking the passage of exhaust gas which will stop the engine when the pressure has built up in the exhaust system. As the pressure reduces (it would be holding the baffle in its blocking position) the baffle may clear and then the engine will start as normal. This then occurs again when the pressure builds up. Suggest you remove the silencer and run the engine. If the fault does not come again then you know what the answer is.
  8. #8 Re: Non-starting problem
    Oct 2018
    Cambridgeshire
    50
    Thanks. I'll give it a go.
