holding the bonnet halves up
  • holding the bonnet halves up
    Has anyone invented a good design for holding both bonnet halves up at the same time ?
    4th Marlin owner
    Re: holding the bonnet halves up
    Not brilliant images as they're snipped from a video I took at Stoneleigh some years ago but they may help. Also, if the owner of the car reads the forum he/ she may be able to provide better detail.
      [ATTACH=CONFIG]12825[/ATTACH]
      [ATTACH=CONFIG]12826[/ATTACH]
      [ATTACH=CONFIG]12827[/ATTACH]
      [ATTACH=CONFIG]12828[/ATTACH]
      Thanks Jon, interesting pictures.
      4th Marlin owner
        Mine came with little gas struts, unfortunately with both of them up, one or other does tend to fall down, perhaps stronger struts would work better.
        If I am working under the bonnet, I loop an old fanbelt over the studs.
        Formally DonSayers on here.
          This was Bob Jacksons answer to the problem
            that looks a really good easy option , thanks to bob jackson
            terry
            4th Marlin owner
              hmm , the fan belt looks easy , i like the struts as well, thanks
              terry
              4th Marlin owner
                My gas struts have definitely gone weak, I shall order some new ones when I have a little spare cash.
                  The struts on my bonnet had zero gas in them and a previous owner had used a piece of plastic pipe cut lengthways to act as a wedge.
                  I swapped them out for these off eBay last year.
                  So far they have been great. 50N is plenty strong enough unless you're out in a very high wind.
                    thanks very much , really handy info, i shall get them , just the job
                    i couldn't possibly see a picture of where / how they are installed could i ?
                    i think they look far more professional than pieces of rod.
                    4th Marlin owner
                      This is the struts installed. Piece of aluminium angle on the bonnet and a bracket on the bulkhead.
                      (I'm not sure why, but the photo seems to have attached twice, even when I deleted the original and re-attached).
                        Where could I find the ball ends , or whatever they are called,, thanks
                        4th Marlin owner
                          They come on the Gas struts, just make sure you select the correct type when purchasing.
                            Oh thanks , that’s unusual, the struts for my estate back door were just struts, thanks again.
                            4th Marlin owner
