Results 1 to 5 of 5
Thread: B Series Engine Oil Cooler
  1. #1 B Series Engine Oil Cooler
    club member Club Member
    Feb 2020
    Bedfordshire
    207
    Has anyone fitted an oil cooler to their B series engined Roadster and if so was it beneficial?
    The engine I am fitting is tuned to stage 2 and I am wondering if an oil cooler may be worthwhile. Fairly cheap and easy at this stage of the build...
    Cheers Robin.
  2. #2 Re: B Series Engine Oil Cooler
    Nov 2016
    135
    Believe it was standard fit on MGB so why not !
  3. #3 Re: B Series Engine Oil Cooler
    club member Club Member lil_red_roadster's Avatar
    Telford, Shropshire
    673
    I'm not sure one is needed on a Roadster; whilst it was fitted to the MGB IIRC it wasn't fitted to the Marina TC.
    If you do decide to fit one make sure you also include a thermostatic valve so it only cuts in if/when actually needed.
  4. #4 Re: B Series Engine Oil Cooler
    Feb 2020
    Bedfordshire
    207
    Thanks for the answers. My thinking behind the question was:
    The engine bay on the Roadster is pretty compact. Anything that helps dissipate heat must be a good thing.
    My engine is tuned = more heat. On the other hand so is the one in Lil Red Rooster and I guess you don't have overhating problems.
    And yes I believe it was fitted to the MGB as standard.
    Cheers Robin
  5. #5 Re: B Series Engine Oil Cooler
    club member Club Member boustrophedon's Avatar
    Apr 2019
    82
    My B-Series engine in a roadster had an oil cooler, but the pipes were all perished so I took it off, made absolutely no difference.
    Formally DonSayers on here.
