Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
Thread: Escort fuel gauge
  1. #1 Escort fuel gauge
    Downley, High Wycombe, Buckinghamshire
    2,134
    Has anyone tried to fit the fuel gauge from the Escort Mk1 and 2 into the Marina 3 dial dash pod?
  2. #2 Re: Escort fuel gauge
    club member Club Member kolmershlagjp's Avatar
    Dec 2015
    avignon {sud de la France]
    150
    look at the link, that's what I did http://www.marlinownersclub.com/foru...der-conversion
  3. #3 Re: Escort fuel gauge
    Dec 2015
    150
    the gauge of a mini can be installed
  4. #4 Re: Escort fuel gauge
    2,134
    Does this work as well?
    Quote Originally Posted by kolmershlagjp View Post
  5. #5 Re: Escort fuel gauge
    Dec 2015
    150
    yes i unsoldered the part on the gauge of a mini shipper and i welded it on the gauge of the escort
  6. #6 Re: Escort fuel gauge
    2,134
    Sorry for so many questions, are you saying that a classic mini fuel sender, when connected to the escort fuel tank sender, reads correctly on the Marina fuel gauge?
  7. #7 Re: Escort fuel gauge
    2,134
    Are you saying that you take the arm unit off the mini sender and weld/solder it onto the original escort sender without the need to cut and shut the pipework
  8. #8 Re: Escort fuel gauge
    club member Club Member lil_red_roadster's Avatar
    Telford, Shropshire
    676
    That's what I did a few years ago...there is a write-up in Pitstop somewhere (2016ish)
    NB - this is a later Sierra unit with a return pipe. Smiths Classic sender unit carefully removed & soldered onto the Ford pickup.
  9. #9 Re: Escort fuel gauge
    2,134
    There are a number of different TB9010 sender units.
    Does anyone know the ohm range for the Marina?
  10. #10 Re: Escort fuel gauge
    2,134
    Hiya lily red roadster
    I have the Ford sender out but using a normal soldering iron doesn't move it.
    Can you remember what you did to remove the arm mechanism?
