clutch 1300 marina.
  • clutch 1300 marina.
    my clutch is juddering where the best place to by one from.also do spline dia same thro range. can not find engine no. not on right hand side or anyware
    Re: clutch 1300 marina.
    The 1.3 clutch plate is a smaller dia and less splines than the 1.8.
    Cant say that one supplier is better than the other.
    Clutch judder is invariably due to a glazed flywheel/pressure plate, only visible once you strip everything apart. Pressure plate can be replaced, but the flywheel may require light machining, a second hand one, may be exactly the same.
      Before you go pulling the box out to change the clutch, check the engine mountings are intact and its not the engine jumping up and down.
        Good call.
          thank you for your help
            Also gearbox mounting
